주요 콘텐츠로 건너뛰기
2009년 중반기 모델 A1278 / 2.26 or 2.53 GHz Core 2 Duo 프로세서 EMC 2326
745 질문 전체 보기
Are 2.26 GHz and 2.53 GHz processor logic boards interchangeable?
I have a mid 2009 13" Macbook Pro (A1278) MacbookPro5,5. My logic board has clearly been failing for quite some time now so I am planning to swap it out for a new one as it is significantly cheaper than buying a new laptop all together. I wondering If I can use the 2.53 GHz processor logic board from the same year instead of the 2.26 GHz. In the link below it shows them both as being parts for this upgrade but doesn't specify if they are interchangeable. They appear to the same shape. And when I looked the 2.53 model up online is says:
Compatible Model(s): MacBook Pro 13.3" 2.53GHz Core 2 Duo (MB991LL/A, A1278, MacBookPro5,5) - Mid 2009
I just want to be sure it will work before I order the part.
MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement
Thanks for your help!
P.s.
Where do you buy more of the little black (phillips 00) screws that are used for almost everything inside this laptop? Ive seen plate screws, hard drive screws and keyboard screws online, but none of them look right to me.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Reece Thompson same model, same year, just a different processor is interchangeable.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Reece Thompson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 145
