주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2006년에 출시된 Canon PowerShot A 시리즈 포인트 앤 슛 카메라로, 600만 화소 카메라와 4배 광학 줌 렌즈를 탑재하고 있습니다.
DIY "hot" spring fix
I have an A530 that was included in the recall for the "hot" spring but I didn't know about it and Canon won't fix it now. Does anyone have a diagram of what the problem was and the DIY fix that I've seen talked about, but never described?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
John Darago this was recalled because a little hinge spring in the door of the battery compartment can stick out and short the batteries. Result is poor battery life, and a hot battery door.
이미지
You could try to shorten the spring, use a small Dremel like tool with a cut of wheel or simply place a piece of electrical tape over it.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I don't know if all A530s are like this, but I took the battery contact plate off by removing the two screws. The back side of the plate had a slot that the arm of the spring was supposed to fit into. I guess when it was assembled, the spring arm wasn't placed properly. If you decide to examine this, be careful. There is a little spring behind the plate that could "spring" away.
의
Those springs in the battery doors are the major reason why I do not like to work on cameras. A royal PITA to deal with those :-)
의
댓글 달기
답변을 추가하세요
John Darago 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 5
지난 30일: 23
전체 시간: 681
