주요 콘텐츠로 건너뛰기
The Canon PowerShot G11 is a point-and-shoot digital camera designed to be easy to use for photography enthusiasts.
12 질문 전체 보기
Do you have a guide for replacing the LCD and the LCD cover?
On my Canon PowerShot G11, the LCD is broken and the case that holds the LCD is dented. I need to replace the LCD and the case as a unit. Do you have a guide for doing this? If not, is this something that I can figure out based on your guide for replacing the rear cover?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
@jthomson29 this should work for you:
You may have to do a bit of searching but every now and then parts are available at places like this.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I am pretty sure you could figure it out from the rear cover replacement guide, it looks like it is just two or so more screws then it comes off. The problem is going to be finding a replacement that comes as the whole unit not just the screen.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jim Thomson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 5
전체 시간: 223
