주요 콘텐츠로 건너뛰기
Need to find a driver for this printer
I've had this printer, the HP Deskjet 3845, for many years and it still works. I had to upgrade my computer and this time I can't find a driver. The guy I bought the replacement computer from is searching my old hard drive for a driver, but it occurred to me that there might be other people still using this printer who have the driver available. HP no longer will provide a driver, although...you can still buy the ink cartridges...and that makes no sense to me.
Any suggestions or solutions?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Is your PC windows 10 or 8?
Windows 7
I've tried the internal drivers and that doesn't deliver...
댓글 달기
답변 2개
선택된 답변
If the person who has your old computer or hard drive would look in '''windows /program files '''they find the driver for your printer. If they find it , they should copy it to a flash drive. You can then download it to you r new computer. I have check some website for a solution to your problem. There are websites that have the drivers for your printer. Most of them want you to download their software for a cost. I looks like your printer is rather old and according to HP they do not support products that are ten years old or older. I might suggest that it is time to invest in a new printer. Depending on what you use your printer for and frequency you r investment in a new printer may be cost effective. If new is not in you budget, you might want to look on Amazon or E bay for a good late model printer. Hope this helps.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
Hi
Try the following, if you haven't already done so.
Go to Start > Devices and Printers > right click on your printer > select ''Printer Properties ''(not Properties) > Advanced > New Driver > When the Wizard open select next > Find and select your printer from the list > Windows Update and follow the prompts.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Printer properties wasn't one of the options. But thanks for trying to help!
댓글 달기
귀하의 답변을 추가하세요
Deborah Kahn 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 5
전체 시간: 816
