주요 콘텐츠로 건너뛰기
Samsung Galaxy S5 NEO (SM-G903F)는 Full HD 해상도 5.1인치 Super AMOLED 화면을 장착하고 있습니다. 전면 카메라와 후면 카메라는 각각 5 megapixels과 16 megapixels로 작동합니다. 휴대폰 내부에는 64-bit Samsung Exynos 7580 프로세서, 16GB 내장 메모리, 2GB RAM 및 2,800mAh 배터리가 장착되어 있습니다. 치수는 142 x 72.5 x 8.1mm, 무게는 145그램 입니다. 최초 S5와 비교하여 Galaxy S5 Neo는 전면 카메라, FM 라디오 및 더 빠른 LTE (Cat6)와 같은 더 나은 기능을 제공합니다.
Battery compatibility between S5 vs S5 Neo
For starter I live in Canada so my provider is Bell. I have a Samsung galaxy s5 neo (SM-G903W). My phone stopped charging fully. It will charge to 30% or 40% overnight(8 hour period). I do not have a similar battery to swap in and I want to be sure to buy the right one. On ebay I found battery for s5 but they do not have the same amperage so I'm wondering if I could damage the phone by installing a battery designed for a s5.
(Sorry for my English, not my first language)
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 6개
가장 유용한 답변
Yes, the battery of the S5 is compatible with the S5 Neo. A Samsung staff member wrote this in a forum, so I guess (and I hope) it's a good information!
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I did a live chat with Samsung today. The guy told me that the S5 & the S5 Neo batteries were NOT compatible! Seem to be hearing conflicting info..... i will call Samsung products dept. on Mon.
Charlene Yowney
댓글 달기
Galaxy S5 Neo – exactly the same as the previous Galaxy S5. Both has a 2800 mAh battery. However comparison always depend on the screen brightness set to 120 cd/m2, Wi-Fi turned on and 3G, Bluetooth and GPS turned off (except for the 3G web browsing test, of course).
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Yes, they are interchageable
이 답변이 도움이 되었나요?
점수 1
댓글 달기
These pictures should answer your question. If they don’t, look at the Charge Voltage in V (Volts) and mAh (milliAmp hours), and the Nominal Voltage in V (Volts). BOTH OF THESE NUMBERS MUST MATCH! The mAh, however, does not; it simply determines how long it will last, based on Amp hours. I unfortunately don’t have the proper calculations in front of me, but, the higher the number, the better.
But, if you look at the pictures, both batteries share the exact same figures, and the exact same charging ports on the corner of the battery. The 903 and 900 are identical, in my eyes.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I don't think they are compatible. Your battery is probably EB-BG903BBU (like mine). The S5 takes EB-BG900BBU. From what I have read, they are not the same.
https://forums.androidcentral.com/samsun...
(see last comment by bill hughes2)
I found 2 places that sell replacements for the S5 Neo:
https://www.canadianbatteries.com/batter...
http://www.batterybuyer.com/samsung-gala...
Good luck
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I shopped on ebay for a battery for my S5 Neo too. I actually bought one for an S5. I did a live chat with Samsung.ca and the guy told me that the two both use different batteries.
Yet, i cant seem to find one for my Neo! Not sure what is right......
Charlene Yowney
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I have two Neo motherboards, two S5+ motherboards, and seven S5 motherboards on my bench. The same 2.8Ah battery fits all of them.
댓글 달기
답변을 추가하세요
Samuel blais 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 33
전체 시간: 14,062
