์ฃผ์š” ์ฝ˜ํ…์ธ ๋กœ ๊ฑด๋„ˆ๋›ฐ๊ธฐ
Samsung Galaxy S5 NEO (SM-G903F)๋Š” Full HD ํ•ด์ƒ๋„ 5.1์ธ์น˜ Super AMOLED ํ™”๋ฉด์„ ์žฅ์ฐฉํ•˜๊ณ  ์žˆ์Šต๋‹ˆ๋‹ค. ์ „๋ฉด ์นด๋ฉ”๋ผ์™€ ํ›„๋ฉด ์นด๋ฉ”๋ผ๋Š” ๊ฐ๊ฐ 5 megapixels๊ณผ 16 megapixels๋กœ ์ž‘๋™ํ•ฉ๋‹ˆ๋‹ค. ํœด๋Œ€ํฐ ๋‚ด๋ถ€์—๋Š” 64-bit Samsung Exynos 7580 ํ”„๋กœ์„ธ์„œ, 16GB ๋‚ด์žฅ ๋ฉ”๋ชจ๋ฆฌ, 2GB RAM ๋ฐ 2,800mAh ๋ฐฐํ„ฐ๋ฆฌ๊ฐ€ ์žฅ์ฐฉ๋˜์–ด ์žˆ์Šต๋‹ˆ๋‹ค. ์น˜์ˆ˜๋Š” 142 x 72.5 x 8.1mm, ๋ฌด๊ฒŒ๋Š” 145๊ทธ๋žจ ์ž…๋‹ˆ๋‹ค. ์ตœ์ดˆ S5์™€ ๋น„๊ตํ•˜์—ฌ Galaxy S5 Neo๋Š” ์ „๋ฉด ์นด๋ฉ”๋ผ, FM ๋ผ๋””์˜ค ๋ฐ ๋” ๋น ๋ฅธ LTE (Cat6)์™€ ๊ฐ™์€ ๋” ๋‚˜์€ ๊ธฐ๋Šฅ์„ ์ œ๊ณตํ•ฉ๋‹ˆ๋‹ค.
21 ์งˆ๋ฌธ ์ „์ฒด ๋ณด๊ธฐ
Battery compatibility between S5 vs S5 Neo
For starter I live in Canada so my provider is Bell. I have a Samsung galaxy s5 neo (SM-G903W). My phone stopped charging fully. It will charge to 30% or 40% overnight(8 hour period). I do not have a similar battery to swap in and I want to be sure to buy the right one. On ebay I found battery for s5 but they do not have the same amperage so I'm wondering if I could damage the phone by installing a battery designed for a s5.
(Sorry for my English, not my first language)
์ด ์งˆ๋ฌธ์— ๋‹ตํ•˜๊ธฐ ์ €๋„ ๊ฐ™์€ ๋ฌธ์ œ๋ฅผ ๊ฒช๊ณ  ์žˆ์Šต๋‹ˆ๋‹ค
์ข‹์€ ์งˆ๋ฌธ ์ž…๋‹ˆ๊นŒ?
์ ์ˆ˜ 4
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€ 6๊ฐœ
๊ฐ€์žฅ ์œ ์šฉํ•œ ๋‹ต๋ณ€
Yes, the battery of the S5 is compatible with the S5 Neo. A Samsung staff member wrote this in a forum, so I guess (and I hope) it's a good information!
ํ•ด๋‹น ๋‹ต๋ณ€์€ ๋„์›€์ด ๋˜์—ˆ์Šต๋‹ˆ๊นŒ?
์ ์ˆ˜ 2
๋Œ“๊ธ€ 1๊ฐœ:
I did a live chat with Samsung today. The guy told me that the S5 & the S5 Neo batteries were NOT compatible! Seem to be hearing conflicting info..... i will call Samsung products dept. on Mon.
Charlene Yowney
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
Galaxy S5 Neo โ€“ exactly the same as the previous Galaxy S5. Both has a 2800 mAh battery. However comparison always depend on the screen brightness set to 120 cd/m2, Wi-Fi turned on and 3G, Bluetooth and GPS turned off (except for the 3G web browsing test, of course).
์ ์ˆ˜ 1
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
Yes, they are interchageable
์ ์ˆ˜ 1
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
These pictures should answer your question. If they donโ€™t, look at the Charge Voltage in V (Volts) and mAh (milliAmp hours), and the Nominal Voltage in V (Volts). BOTH OF THESE NUMBERS MUST MATCH! The mAh, however, does not; it simply determines how long it will last, based on Amp hours. I unfortunately donโ€™t have the proper calculations in front of me, but, the higher the number, the better.
But, if you look at the pictures, both batteries share the exact same figures, and the exact same charging ports on the corner of the battery. The 903 and 900 are identical, in my eyes.
์ ์ˆ˜ 1
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
I don't think they are compatible. Your battery is probably EB-BG903BBU (like mine). The S5 takes EB-BG900BBU. From what I have read, they are not the same.
https://forums.androidcentral.com/samsun...
(see last comment by bill hughes2)
I found 2 places that sell replacements for the S5 Neo:
https://www.canadianbatteries.com/batter...
http://www.batterybuyer.com/samsung-gala...
Good luck
์ ์ˆ˜ 0
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
I shopped on ebay for a battery for my S5 Neo too. I actually bought one for an S5. I did a live chat with Samsung.ca and the guy told me that the two both use different batteries.
Yet, i cant seem to find one for my Neo! Not sure what is right......
Charlene Yowney
์ ์ˆ˜ 0
๋Œ“๊ธ€ 1๊ฐœ:
I have two Neo motherboards, two S5+ motherboards, and seven S5 motherboards on my bench. The same 2.8Ah battery fits all of them.
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๊ท€ํ•˜์˜ ๋‹ต๋ณ€์„ ์ถ”๊ฐ€ํ•˜์„ธ์š”
Samuel blais ๋‹˜์€ ๋Œ€๋‹จํžˆ ๊ณ ๋งˆ์›Œ ํ•  ๊ฒƒ์ž…๋‹ˆ๋‹ค.
์กฐํšŒ ํ†ต๊ณ„:
24 ์‹œ๊ฐ„ ์ „: 2
7์ผ ์ „: 13
30์ผ ์ „: 29
์ „์ฒด ์‹œ๊ฐ„: 13,463
