주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
782 질문 전체 보기
Error -36 with SSD hard drive
Hello everyone,
I just changed my hard drive with a new one which is a SSD "samsung EVO 850 EVO". It works well and I can write this message with my mac without problem.
The only one is when I'm copying more than one file on my computer from an external disk. The error -36 is displayed and I need to copy each file one by one (and sometimes it doesn't work). The hard drive is formated with a GUID partition and a MAC OS extended (journalised, encrypt). One of you has ever encounterd this issue and know how to fix it ?
Thanks a lot,
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
You'er hitting a known issue with the drive cable.
You'll need to replace it, follow this IFIXIT guide: MacBook Pro 13" Unibody Early 2011 Hard Drive Cable Replacement. You'll want this version of the cable (the better design): MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable - Apple P/N 923-0104
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable 이미지
상품
$34.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Before completing any work, please do a complete backup if this Mac. The last thing you want is some data stored on the drive to get lost in the process. Thanks!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hello Justin and Dan,
Thank you for your quick answer !
I'm going to replace it, I hope it will work.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Arnaud G 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 115
