주요 콘텐츠로 건너뛰기
2011년 하반기 모델, A1278 / 2.4 GHz i5 또는 2.8GHz i7 프로세서.
591 질문 전체 보기
Replacing failing hard drive (the original 500GB one )
I would like to buy a 1TB ssd drive to replace said failing HD, after having the local apple store guys diagnose it as such ... and am set to buy all parts including the solid state drive from IFIXIT, and do the work myself. This is the 13" late 2011 unibody Macbook-pro laptop.
I own no tools yet, except for the mini-phillips for removing the back face of the laptop.
So, my question is:
Do I just buy the ssd part sans fixit kit, but add the spudger and torx wrench into the cart with it, or do I buy the SSD with fixit kit, and rely on it to include said spudger/torx parts?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Please give us the specifics of you machine, year, model number, etc.
Thanks you for changing the question to include specifics.
댓글 달기
답변 2개
선택된 답변
Your model is known to have issues with the hard drive/IR cable. I recommend replacing with the 2012 13" model.
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
Please tell us what is happening with your drive. If the problem is the cable and it has gone on for a while, it can destroy the hard drive.
Here's how to replace it: MacBook Pro 13" Unibody Late 2011 하드 드라이브 교체
Consider replacing with one of these:
Buy these parts
1 TB SSD Hybrid 2.5" Hard Drive
500 GB SSD Hybrid 2.5" Hard Drive
256 GB Solid State Drive
128 GB Solid State Drive
Universal Drive Adapter - migrate data
MacBook Pro 13" Unibody Hard Drive Bracket
These are all listed in the guide.
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable 이미지
상품
$34.99
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
It could go either way. If you want to be safe, just buy the parts you know you need.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Daniel Moore 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 72
