주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
Nexus 7 usb data damage
Hello, I have applied 5v to the data (minus) and (plus) side when dealing with the otg cable. Currently, when I connect a computer tablet, it does not appear in Device Manager and there is no notification on the tablet. The tablets do not react when I connect a USB device with otg. Could I have hurt the motherboard? Do I have a chip circuit component that I need to check on the motherboard?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
help need please
댓글 달기
답변 2개
선택된 해법
Hi,
Just verifying that there is no response either when you are using a standard USB cable. Is this correct?
Why did you apply 5V to the data lines?
Here is an image which shows how an OTG cable is wired if that is what you were trying to do. You apply an Earth (or Ground) to pin 4 in the cable end which plugs into the device.
(click on image to enlarge for better viewing.
Applying 5V to either of the data lines would definitely cause a problem.
I'm not entirely sure but the USB controller function could be incorporated into the main CPU IC on the motherboard. You might be lucky in that there may be components between the USB connector and the IC that may have been damaged and not the IC itself, but it may be difficult to find without a schematic diagram.
Also it would be easier to replace the motherboard than to try and replace the main IC if it is faulty.
Here is a link to the Ifixit guide on how to replace the motherboard
Nexus 7 Motherboard Replacement
Depending on your model version, here is a link to the ifixit's shop motherboard spare part. It is just shown to give you an idea of the price. It may be that it is the wrong motherboard for your tablet.
Nexus 7 (2nd Gen Wi-Fi) Motherboard
If it is the wrong one or that the price doesn't suit you, to find other suppliers search online for (insert your tablet model number) motherboard replacement part to get results that may suit you better.
Update (03/16/2017)
Hi @yekta ,
Here is a link to the ifixit 1st Generation motherboard. (it says that it is the last one they have)
Nexus 7 (1st Gen Wi-Fi) Motherboard
Replace a corroded, damaged, or malfunctioning main circuit board assembly. This motherboard is compatible with the 2nd generation 2013 Wi-Fi model Google Nexus 7 (manufactured by Asus). 이미지
제품
$14.99
Replace a corroded, damaged, or malfunctioning main circuit board assembly. This part is compatible with a 1st generation 2012 Wi-Fi model Google Nexus 7. 이미지
제품
$15.99
이 답변이 도움이 되었나요?
점수 4
댓글 달기
Thank you so much! I do make the OTG cable myself, I mistakenly think that I applied 5d to the data line. Do not you sell the first-person nexus motherboard?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
yekta 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 20
전체 시간: 371
