주요 콘텐츠로 건너뛰기
The PlayStation 3 Slim is the second version of the PS3 video game console with the original model number CECH-2000. Produced by Sony Computer Entertainment it fixed many issues of the original (fat) Playstation 3. It was released on September 1, 2009.
465 질문 전체 보기
very slow load on start up and loading game
Take forever to start up and to load my games and movies what should I do.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
My PS3 will load dvd movie fine but takes forever to load games as much as 30 min. I am not online anymore just arcade now.
댓글 달기
답변 5개
선택된 답변
A hdd is most likely the problem, so I recommend replacing it with more durable much faster ssd.
There is a guide here on how to replace the hdd, but you will sill need to put playstation os on it for it to run.
SSDs are more expensive than HDDs, but the speed boost will be mind blowing.
You can get a ssd here: https://www.amazon.com/PNY-CS1311-240GB-...
Or a SSHD (better than HDD, but still much slower and cheaper than a SSD): https://www.amazon.com/Seagate-2-5-Inch-...
Or just a regular HDD: https://www.amazon.com/Seagate-Barracuda...
Hope this helps!
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
That's a well articulated answer @pccheese !
댓글 달기
Sounds like this could be a failing hard drive. Hard drives are known to start running more slowly and when going bad. I would advise backing up any important information as soon as you are able to and then try installing a new hard drive into the PS3. Keep in mind you will have to install the PlayStation OS onto the hard drive before it will boot up. There are many guides online for how to install the software. Best of luck!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hello there
I've just cleaned my ps3 yesterday i had some slow downs after I did clean the fan, psu unit and case its seems to run a lot faster from when I got it i saw a load of dust i gave it ago to myself and it worked out okay.
Hope this helps to.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
So I plug in my WWE '12 game, and when it's installing the game data, it's stuck on 56%. Anyone have a solution?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
it's because you have to many people on devices
댓글 달기
Yeah. I just turn off the ps3 when the fan makes a loud noise and it loads slow. Sometimes the loading works when I’m done with the ps3 and come back to it after giving it a break.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
arnoldo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 23
30일 전: 114
전체 시간: 31,726
