주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
i6 Stuck in a Boot Loop to Grey/Static Screen
Hi All,
I have an iPhone 6 here which is stuck in a very obscure boot loop. The video should demonstrate it. However, If i force reset it (lock screen and home button) it will boot normally to the lock screen for a couple of minutes, before going back to its boot loop without being touched.
Any known ways of fixing this?
Cheers
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 4개
Backup data if you can first then try updating the phone via iTunes.
@benjamen50 , see there's another one of those boot loopers. There doesn't seem to be any consistent reason why this happens.
Yeah seems to be a common occurance on iOS 10 especially. I have no idea why it happens other than unstable OS.
I think we've covered this before. It sounds like Apple is doing this intentionally. Or another one of their mistakes. Haha. Same thing!
댓글 달기
답변 2개
선택된 답변
Nope, couldn't get it working at all. After a while of non usage it would work for a bit before glitching. I think it needed the solder heating and re-melting, however not sure.
I ended up selling it for parts which resulted in the best solution.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I am facing the same issue, Were you able to solve it Lewis?
Your response is much appreciated. Thanks!
댓글 달기
가장 유용한 답변
What happened to the phone for it to get stuck in the boot loop? Was it repaired, fall in water or something else?
You could try to download ReiBoot or 3uTools to see if they recognize the phone. If you have a recent backup, then you could also try a DFU Mode Restore (you will lose your data).
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Only the normal drops of daily usage, no water damage or anything else. Did get taken to Apple who were clueless about it.
Will try the tools, thanks
@lwatson99 I am facing the exact same issue Lewis, Were you able to fix it? Any pointers would be very helpful. Cheers!
댓글 달기
귀하의 답변을 추가하세요
Lewis Watson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,245
