주요 콘텐츠로 건너뛰기
laptop not detecting HDD disk
I have "DELL Inspiron 14 N4050" when i turns it ON BIOS starts and then black screen appears with massage "PXE-M0F: media test failure ,check cable." and "PXE-M0F: Exiting PXE ROM". i hear a beep with these massages on black screen.
when i tried to sort it out by myself i come to know its HDD disk is not being detected.can i get my data back? if yes then how?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
what if i do not change BIOS IC and purchase a new PCB controller and replace with older one?
and what if i replace the PCB controller with some other hard disk of same model laptop. @oldturkey03 oldturkey3
댓글 달기
답변 2개
선택된 답변
Usman Rasheed like mathiasaat stated, check the drive on another computer first. Sometimes there is a possibility to recover the data by replacing the HDD controller board. This will only work if the drive did not suffer a mechanical failure. In case of mechanical failure you will need the tools and knowledge that data recovery companies have (very expensive). To change the controller board, take a look on here. Different drive, same idea.
해당 답변은 도움이 되었습니까?
점수 2
댓글 8개:
thankyou so much for your answers .... i will try by putting this drive in some other laptop.....
If you have a desktop, it will be easier. It will be easier yet if you have a SATA to USB adapter or HDD case.
if there is problem with PCB controller can i still access my HDD by SATA to USB adapter @George Abraham
Usman Rasheed no you cannot. If your controller board has failed it does not matter how you install your drive. It will not work. You would have to install the controller from the same make and model hard drive. If you give us all the information from your drive, we can try and help you find the right board etc. Even that is not always easy to find....
Yes, but if the problem isn't the board, you can still use the HDD to USB adapter. The problem may be with the laptop.
댓글 3개 더보기
댓글 달기
가장 유용한 답변
Hello!
The problem could either be the HardDrive it self, or the the bridge that connects the hdd to computer. Have you tried to connect the hdd to any other computer?
If this is not working the harddrive is probably dead. There are companies that could save your data but it is expensive.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Usman Rasheed 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 162
