주요 콘텐츠로 건너뛰기
The Motorola Razr V3c is a CDMA2000 version of the Razr.
#7 on key pad is very intermittent (3%)
#7 on keypad hardly ever connects. Verizon sprayed a cleaning product on the external keys. The key "clicks" but rarely makes contact. I like the phone. Repair shops quote $40 to replace the entire keypad.
Thanks for any input.
Joe
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
maybe try taking the plastic frontage off the keyboard and layering a tiny bit of tinfoil underneath it, so the contact has something to touch?
I've done this with other types of buttons before, I believe it might work for you. it's worth a shot, anyway.
hope that helps!
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thank you!. Now I try then I tell you
I would use the guide to remove the keypad and would clean the contacts under the adhesive that holds the half button - i never yould use something that could shorten anything inside a phone
댓글 달기
답변을 추가하세요
jbass43314 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 1,553
