주요 콘텐츠로 건너뛰기
Samsung에서 제조한 Samsung Galaxy Note 5는 (Note5로 불림) 스타일러스를 탑재한 phablet/패블릿 스타일 휴대폰입니다, 2015년 8월 출시.
271 질문 전체 보기
Can I use UV Loca to glue on the back door?
Hi, I broke my camera for my note 5 and I bought a new one in order to fix it. I also bought a tool set but I realized it came with UV loca glue stuff in order to glue on the screen. But I'm only replacing the camera and I thought it was adhesive. So I was wondering if I could use that loca stuff as adhesive for the back??? Idk much about this stuff lol sorry.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Hi,
Unfortunately loca needs UV light for it to cure, and since the back isn't see through, none of the light would get through.
Not only that, it would also get in to places that could damage the phone itself.
Get double sided adeshive and use that, you can usually get pre cut stuff for it as well. :-)
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
If you can get a UV lightsource to cure loca glue, then it might work out. However, you would need see through material to make sure that the light comes through. To learn more about how loca glue works, check out the article below.
http://vkrepair.com/loca-glue/
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Cringe 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 655
