What does this error code mean?
4sns/1/40000001:1tb1t-0.000
this is the error code it gave me. Please help me know what is the error. email me at enriqueluis.spiddy@gmail.com thanks
좋은 질문 입니까?
좋은 질문 입니까?
After a heck of a lot of searching, here's what I found:
4sns refers to a thermal sensor acting up
1tb1t refers to one of the thermal sensors in your battery malfunctioning (weird, huh? I was surprised too)!
First, reset your PRAM/NVRAM (it's always a good first step to try).
If this doesn't work, replace your battery (which machine do you have? If you're not sure, use ID your Mac).
해당 답변은 도움이 되었습니까?
Congrats-I looked for some time and could not find it. Where did you find it? Ralph
hi. actually i don't have the battery in place when i did the test cause the battery needs to be replaced so i removed it. I already ordered a new battery and still wating for it as soon as i have it, i will run again the test and see if the problem is solved. thanks for your reply guys.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,847
댓글 6개
Googling this returns 0 results, sorry. Also, people can answer the question here rather than email you.
QEII Student IT 의
Couldn't find it at Apple support either. Ralph
rj713 의
@QE, usually googling these returns 0 results, you have to google parts of the code.
rab777hp 의
That's true but if this problem is recurring, someone else would have posted this same code online. Clearly though, they haven't.
QEII Student IT 의
No, these codes get posted online, but because of the format, with symbols such as colons, google interprets them as search operators and doesn't do a straight search of the whole string.
rab777hp 의
댓글 1개 더보기
