Reversing light comes on occasionally when breaking
Since having my reversing lights repaired at a garage, they come on occasionally when I break. Drivers behind me are worried! I can't recreate the fault when stationary tho. Help!
좋은 질문입니까?
좋은 질문입니까?
Hi,
If the work was carried out recently to repair the reversing lights by a garage, there should be some sort of guarantee on their workmanship, provided by them, even if it is only for 30 days etc.
Take the car back to them and explain the problem and show them as well (hopefully the problem will happen when you do this) and ask them to check it out, as it is causing problems for you..
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 4
지난 30일: 17
전체 시간: 496
댓글 2개
does the reverse light work when you have it in reverse gear??
pascal molenberg 의
Yep, reverse light works when in reverse gear and I can see it when it's stationary
sophie 의
