주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
Screen Replacement Problems and Buttons Not Working
I dropped my iPad mini over a year ago and smashed the digitizer display. i replaced this and then the lcd screen broke too so i replaced that but i did this without disconnecting the battery as i did not know that i needed to disconnect it. after doing this, the screen would not come on but the iPad would make sounds e.g. when it was charging.
i read up about the problem and found that i may have blown a fuse on my board for the backlight. so i just left the iPad on a shelf and didn't use it for several months. i picked it up today and plugged it in to see if anything happened and the battery charging icon came on the screen. now the screen works and sound works.
except, my digitizer is not stuck to the ipad but is connected and when i touch certain parts of the screen, other parts interract or nothing happens at all. also, the home and power button now seem not to work but the power button only works when it is held down to power off the device.
has anybody had this problem before or know how to solve this. someone wreckons that they could repair it for £45 but it seems too good to be true.
thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
The mini is notorious for digitizer problems. Depending on where you bought it, it may require that you add some kapton or similar tape along the bronze/silver metallic border at the bottom of the "window". When there is no tape, it can conduct with other components and cause ghost touches etc.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
jacobmaddox123 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 10
전체 시간: 118
