주요 콘텐츠로 건너뛰기
The OP-1 is a portable music workstation incorporating a synthesizer, sampler, sequencer, multitrack recorder, drum machine, mixer, and controller. It was released in 2011.
Why does the lower half of my keyboard not trigger?
Hello. The lower half of my keyboard on op1 is not working. Also my USB port has pushed through housing. Does anyone know how I can fix it or where I can have it fixed? Thank you
Chris
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Non-working, or intermittently working keys are most likely due to a glitch in the connection between the OP-1 Keyboard and the rest of the unit. If you want to try to fix this yourself then we suggest that you follow this guide. Basically start by removing the keys to uncover the screws, unscrew and lift the keyboard module, then remove and reinsert the connectors. Sometimes this resolves the issue, at least temporary, and a keyboard replacement is not needed. Good luck!
Please note: You will void any remaining warranty by doing this.
Replace the Teenage Engineering OP-1 keyboard module and fix an unresponsive key. This part includes 12 loose keys. 이미지
제품
OP-1 Keyboard
$119.99
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Chris leidy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 679
