주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
Why is the memory overheating
Hi
I have iphone 6 , stop suddenly.
When I connect it to the power supply and turn it on, the Amps goes to almost 1 amp
And the monory is overheating, can't touch it .
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
This is a belated answer so hopefully it can be of use to folks who search for and find this question.
The iPhone 6 should pull ~1A when charging so that may be normal, unless of course the battery is already fully charged.
However, the memory IC (NAND) should not be "untouchably" hot. This could point to a short circuit within the NAND or any nearby circuitry. If you're lucky, then the NAND may be undamaged but if it is damaged, then you will have lost all of the data. This type of failure can be repaired in certain circumstances by an experienced micro-solderer but as of today (June 2018) may not be economically viable on an iPhone 6.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Ahmed 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 57
