주요 콘텐츠로 건너뛰기
Could it be the scree on the flex?
Hi.
Half the screen has a pink shade. It got better by hitting the sides of the screen but now it doesn't help.
I disassembled the screen and moved the LCD while connected to the Flex cable but nothing changed, i also disconnected the flex from the LCD and the motherboard and nothing happened.
i'm adding some pictures for you to see. Photo 1Photo 2Photo 3Photo 4
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
It's not the GPU. i plugged to an external monitor and it works fine.
Also yes, i disconnected the flex from the LCD and the motherboard and reconnected it again and the problem persisted.
I think this is a problem related to the LCD.
댓글 달기
답변 1개
선택된 답변
Hi,
Not sure quite what you mean when you say I also disconnected the flex from the LCD and the motherboard and nothing happened. Did you mean that you disconnected and then reconnected the flex cable and the display still exhibited the same problem?
Try connecting an external monitor to the laptop and see if its' display is normal.
If it is the same as the LCD screen then there is a problem with the GPU or the motherboard.
If the external monitor's display is normal then there is a problem with either the video cable, video cable connections at either end or the LCD screen.
As you have removed/reinserted? the video cable then the problem is most likely a faulty LCD screen.
Here is a link to the service manual for your laptop. Scroll to p.69-70 to view the necessary pre-requisites and then the procedure to remove the LCD module. Then scroll to p.94 item #1 to view the part number(s) for the LCD module. Once you have determined the correct part number for your particular model variant (the number should also be printed on the back of the LCD screen in your laptop) search online using just the part number only to find suppliers of the part.
https://download.lenovo.com/consumer/mob...
Hopefully this is of some help.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Pigoath 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 89
