주요 콘텐츠로 건너뛰기
다섯 번째 Google Nexus 휴대폰. 2013년 10월 31일에 공식 발표되었으며 4.95” 1080p 스크린, 2.26GHz Snapdragon 프로세서 및 LTE 지원을 자랑합니다. Android 4.4.2, KITKAT. 제조사는 LG.
222 질문 전체 보기
Where are the leads of the BL-T9 battery in the Nexus 5?
I can't find the positive and negative leads on the BL-T9 battery to test for voltage after extracting it from the phone. There appears to be only a single connector to this battery.
Where should the test leads go for this battery with a typical multimeter?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi,
This is a blown up image showing the connector side of the flex cable coming from the battery.
On it you will see the 3 copper coloured connectors in the plug, with what I think is the temperature connector in the middle. By the physical size of the connectors the +ve and the -ve connectors should be the 2 outside ones of the three and using a Voltmeter it shouldn't take much to work out which is which,
click on image to enlarge for better viewing.
Test procedure using DMM -Voltmeter - 20V DC scale
Place Voltmeter red test lead on one outside connector terminal of the battery cable and the Voltmeter black test lead on the other outside connector terminal of the battery cable.
If the Voltmeter has a -ve symbol in front of the voltage reading then the red lead is on the -ve terminal of the battery.
If the Voltmeter shows only the voltage reading then the red lead is on the +ve terminal of the battery.
Ensure that you do not bridge across the terminals with the meter test lead probes when measuring the voltage, as you could s/c the battery.
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
Thanks. I was able to confirm that the battery still held 3.5V for a 3.8V capacity. Now to figure out why the phone isn't registering it.
댓글 달기
귀하의 답변을 추가하세요
Rewarp 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 2,026
