주요 콘텐츠로 건너뛰기
The Xbox One Wireless Controller model 1697 was released in 2015 and replaced the model 1537 controller and fixed some of the problems found on Model 1537 controllers. The Model 1697 controller includes an integrated 3.5mm headset jack, which allows compatibility with most 3rd party headsets without the need of an adapter. This controller has been discontinued and replaced by the Model 1708 controller.
75 질문 전체 보기
My controller doesn't work with batteries
My controller works but only with the USB cable plugged in. It will not work/turn on with batteries in. I have tried new batteries, clean metal conact in controller, updated via usb but still wont work with batteries just cable.
Does anyone have any ideas?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
가장 유용한 답변
Make sure you hold the Connect button (on the XBox).
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
It could be a broken wire or solder joint to the battery port
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
If you continue having issues turning on your Xbox One Wireless Controller, check out this Xbox One Wireless Controller Won't Turn On Problem Page.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Григорий Сака 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 6
전체 시간: 3,400
