주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Note 4는 2014년 10월에 출시된 셀룰러 스마트폰입니다. Galaxy Note 4 모델 번호는 SM-N910, SM-N910A, SM-N910T, SM-N910V 또는 미국 버전은 SM-N910R4입니다.
What caused this? Overload?
So that's it am I right in thinking this is an overload of electricity? I bought it to learn about fixing Samsung's but this doesn't look fixable to someone new like me. There's four burn marks inside the casing I'm not sure what their function is yet the worst one is next to the battery were a tiny piece seems to have come off as well. There is no corrosion so i was thinking not water damage? Or could this be done by something else? Is this recoverable /fixable? Tnx
Update (01/23/2017)
Ok so here are the closest pictures I can do...
four burn places. Tnx
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
@bobbobbob that looks like it could have been caused by anything that created a short circuit. It might be fixable but for that you will definitely have to post more pictures that are closer and clearer to where the scorch marks are.
Update (01/24/2017)
Thank you for the pictures. On closer examination it looks like you burned a lot of the inductors and other components on the board. It also shows that your BT/WiFi IC is burned up. You could try and replace each component as well as the flex cables, but there may be burned traces as well. If you want to you can clean the board and see what other damage there might be. This is pretty intensive and may not be fixable without going in way deeper than you can.
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
Ok nearer pictures up! Hopefully it's clearer? Tnx
Ah ok yes that's what I guessed ...I had almost given up as I'm not at this level yet. I am possibly going to swap out the motherboard if I think I can do it. I was after an analysis as well because I only just got it so I wasnt sure. I've now seen water damage so I can see the difference. And I guess this was a big overload so it will take a lot to fix...Tnx
댓글 달기
답변을 추가하세요
BobBob 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 133
