주요 콘텐츠로 건너뛰기
2008년 10월 출시 / 2.4, 2.53, 2.66, 2.8 또는 2.93 GHz Core 2 Duo 프로세서
376 질문 전체 보기
Battery Connector Pinout and Voltage
I have a Late 2008 MacBook Pro 15" with the removable cover on the back to where you can expose the battery. I noticed my Battery Is Not Charging. Under System Report it shows that it isn't even installed when it is. I've reset the SMC and PRAM and that didn't help. So at this point I didn't know if it was the Battery, Battery Connector, or Logic Board.
I wanted to test the voltage at the battery connector to see what is coming through the logic board to the battery connector but I don't know what the PINOUT and expected voltage is. I hope someone here can help me with that.
From what I can see (see attached picture), there are 5 pins. The middle 3 I get 3.1 to 3.4 volts out of. Looks like the others are ground.
| - ground?
| - 3.1 v
| - 3.4 v
| - 3.4 v
| - ground?
The above is what I'm getting. Not sure what it is really supposed to be?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
I ended up getting ahold of another battery and everything was fine. So it appears that the 3.1 volts I was getting in the above tests were correct and sufficient to charge the battery. Didn't appear to be a battery connector problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
I have seen several problems relating to that battery connector plate. I would suggest checking it for corrosion and/or replacing it.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
steharmon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 25
전체 시간: 3,777
