주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
The front panel assembly cables are overheating after a repair
After completing a repair i was reassembling a repair, and once it was put back together the front pannel cable areas became very hot. What is the cause of this and how can i stop it?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
If you can feel excess heat, then something is shorting or pulling excessive current. Take the screen off, inspect the connectors, inspect the small parts in the screen assembly and re-assemble. You may have a faulty replacement screen or incorrectly mated the connectors.
If you notice anything odd, then report back with more details and we will be happy to help.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
This usually is a result of a short in the FFC flex caused by using metal tweezers.
When I am elected king...I will ban people from using metal tools on electronics.
@joshw now I'm in trouble... ;>)
댓글 달기
귀하의 답변을 추가하세요
Nick Genco 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 54
