주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1624 질문 전체 보기
After installing a new DC-In Board. Boots to white screen immediately
Hi,
So I followed the IFIXIT guide to the T. I will be reassembling it gain after work. It is booting directly to a white screen with fans on full blast,
Now granted I hadn't received my new MagSafe power adapter yet, stupid amazon only delivering in bits and so I just went through and canceled the torx here, but I'll start being more loyal, since it was a free guide.
And of course working for Apple no body seems to have an answer there, it can't be video card because then wouldn't see nothing.
I'll probably order a battery too just in case because the AC light still isn't coming on.
It was working however fantastically last week, so far due to all the added shipping costs I've sent 65 dollars. Any suggestions? I'm going reset everything again.
The most logical answer is a hardware failure but how can I tell if I can't get into diagnostics? Any help would be greatly appreciated. And, yes I was running it without a battery!
I've reset NVRAM during the white screen which makes no sense
Then the System Management Controller (SMC) who knows, but I hold the power button for 20 seconds it will turn on. But still to a white screen.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Quick question, is it wise to take the super drive out and leaving it out. ive never used it one and i wll do the ssd dive thing to it. Once shes up and running again.. I know that shes is starting to fail. but by by god, i'd give up my work station for her, al the fun things we've done toghter. these newer ..faster... macs that Apple gave me dont mean squat other than i have to use them for work.
All i care about is my 13 inch mid 2012 mac..
*!&$!&$^ ups better get here soon with my poewr suply.
댓글 달기
답변 1개
선택된 답변
Could be the hard drive isn't in correctly? Might be worth pulling it out, blowing out any dust around the connectors with a can of air and putting it back in again. Or it could be a failed HDD, do you have another you can put in to test?
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
good advice, i just took out the logic boad, but System Management Controller resets go full circle i used to do a trcik where would plugin a cheeap mark10 charger int a MacBook 2010 to ge her going and since for some reason the onluy way it would start is if something was plugged into its one its usb ports an d then it wold be shorted out. of course neve this to cusomers bu to ge this mac giong id had been shorting the magsafe with a android connector, the magsafe not the acutall MacBook, soi knowthats fault, som taking itall apart
hen puttting itall gether
that aiport part ooks like its goigno suck bu thanksfor he adivice. it wil give me another 5 hours of non stop appel appole aple crazinness
my typos are so bad that what 12 hours does to you.
댓글 달기
귀하의 답변을 추가하세요
mark Andrews 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 76
