주요 콘텐츠로 건너뛰기
Announced on October 16, 2014, the iPad Air 2 is a thinner successor to the iPad Air.
450 질문 전체 보기
iPad not powering after digitiser LCD screen change
iPad Air 2, replaced LCD digitiser screen due to cracked glass and all working fine before replacement. The home button was taken from old one to new one. After connection for trial the screen worked with display but could not use the home button at all. iPad message displayed that the button cannot be used and could not close any opened applications.
Disconnected and tried to fix the home button, meantime try to test and accidentally press the power button when half connected ( 2 connectors ok, but last one still loose).
iPad is not coming on or any display at all pressing any buttons and made sure battery was initially 40% and charged at least for 3 hrs.
Any suggestions guys? To fix it or to make a decision to make up the mind to repair?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
iPad is coming on after battery reset but the following message error coming on. Touch ID, Unable to activate Touch ID on this iPad
댓글 달기
답변 3개
선택된 답변
Have you tried disconnecting the battery and then holding down the power button for 10 seconds and then reseating the battery? You have to pry the motherboard up a little bit in the air to in order to disconnect the battery but it's no big. Also, have you tested with a different LCD?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Thanks for the reply Andy,
I have reconnected with old cracked previously working screen but didn't had any luck. Didn't try disconnecting the battery and don't know how to do it. The iPad is not working may as well try.
Please post any critical do's and don'ts.
Thanks Again
Shashi
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The connection was not correct for the home button and once connected all worked. Thanks Andy and guided forum. The problem fixed and thanks again.
Shashi
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Shashi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 107
