주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
How to adjust flex antenna because I have no wifi or bluetooth?
The wifi was not working neither is my bluetooth. I looked it up and someone said i need to adjust my flex antenna, does anyone know if this is true and if so does anyone have a guide to fix it?
Update (01/28/2017)
Ok she dropped the phone and now the wifi does work but only when she is within 10-15 ft of the wifi base
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hmm...
There's nothing to "adjust" on the antenna. You will want to look to see if the antenna is properly connected to the logic board and housing. Keep in mind that there are several antenna elements in the phone, including the housing. I would use this guide to dis-assemble the device. Read through it first and focus on the antenna elements.
There is also a possibility that you have a logic board issue...you don't really say what happened to the phone prior to the issue. Was it dropped, water damaged, prior repair etc. ?
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
댓글 달기
귀하의 답변을 추가하세요
Nick Genco 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 136
