주요 콘텐츠로 건너뛰기
Repair guides and support for the 5th generation Honda Accord coupe, sedan, and wagon.
87 질문 전체 보기
cannot find any radio codes
i have a older Honda Accord [1996] the battery has been disconnected. cannot find any radio codes
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
You can get a radio code here: https://radiocodevault.com/honda
댓글 달기
답변 5개
선택된 답변
Donny Armstrong , Remove radio at least partially so you can get the serial #, normally on a white tag. Write down the serial # or take a pic., now with your ownership in hand and serial # of radio you can drive to the Honda dealer, provide proof of ownership, give them the numbers, and get your code. You can also contact Honda at links below and hopefully they can email you a code if given all required info.. 1st link shows how to remove radio, 2nd and 3rd link is where you can contact Honda. Good luck.
https://www.youtube.com/watch?v=3hW5eM5F...
https://radio-navicode.honda.com/
http://owners.honda.com/ownership/dealer...
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
thanks alot for the info couldnt do it alone.
Donny, happy to be of assistance, good luck.
댓글 달기
가장 유용한 답변
You can get a radio code here: https://radiocodevault.com/honda/
Hope it helps mate
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
If you can take out the radio and get the device serial number, you can look it up online at the site below. You will also need your VIN.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hello, I think you should read the guide over at the below website, it will explain how you can get a radio code for your 1996 Honda Accord for free, give it a try. I've used it on both mine and my wifes Hondas and it worked perfectly both times. Beats paying the ridiculous fee at the main honda dealer!
http://www.freeradiounlocking.com/brands...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
94 honda accord radio serial number 146035 the code number is 52652
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
What about a 1995 Honda Civic coupe ex
댓글 달기
귀하의 답변을 추가하세요
Donny Armstrong 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 33
30일 전: 124
전체 시간: 11,326
