주요 콘텐츠로 건너뛰기
Apple의 2016년 개정판 노트북은 전문 사용자를 대상으로 제작되었습니다. 15 인치, 2880 x 1800 Retina 화면, 쿼드-코어 Intel Core i7, 256 GB / 512 GB / 1 TB / 2 TB 저장 공간 옵션, 16 GB RAM, 그리고 Touch Bar가 장착 된 키보드가 특징입니다. 2016년 11월 출시되었습니다. 모델 A1707.
260 질문 전체 보기
Keyboarded and touchbar wont work
Hi , I spilled water on my mac , it couldn't turn on up to one week , after that It turned on but my touch bar and keyboard don't work , how can I understand it is related to the logic board or separately to the keyboard touch bar and sound ?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Also how the !&&* did you break that thing anyway?
댓글 달기
답변 3개
선택된 답변
Unplug the battery and clean it asap with this guide:
Electronics Water Damage
해당 답변은 도움이 되었습니까?
점수 4
댓글 14개:
the only thing is that the haptic feedback is not working.. but I feel it worked before I closed the back case
@narimand Good! Is the touch bar and keyboard fully functional? Also can you take out the touchpad and clean that too, and check for rust.
and also my microphone doesn't work, I realised damage parts step by step .
@narimand Clean the LCD cable and post a picture of the socket on the motherboard, these often get damage.
Is there any relationship between a Lcd cable and microphone?
댓글 9개 더보기
댓글 달기
Check the underside of the logic board for liquid damage, and clean with 95%+ isopropyl if there is any corrosion. Sometimes on the 12" Retina (your model), liquid can get under this, usually around the CPU area.
Check the gold pins on both sides of the ribbon which goes from the trackpad to the logic board (curly one). If there is corrosion, this will be burnt, so it will need replacing. Also, check both sides of the cable which goes from the trackpad to the keyboard. It's very likely either the cable(s) or the trackpad PCB is bad if both the keyboard and trackpad aren't working, since the keyboard is plugged in through the trackpad.
If the keys are sticky, the keyboard will likely need replacing too.
Regarding the microphone, check for liquid damage around the small headphone jack board where this plugs in. Sometimes the microphone cable can be burnt, or the board is bad.
To be honest, I would recommend taking it to a repair company which has the testing parts available, otherwise you will find yourself spending a lot of money on parts to test. Try out what I said first though, to see if anything stands out :)
해당 답변은 도움이 되었습니까?
점수 4
댓글 4개:
every parts now are fine , but my microphone won't work
@narimand try the audio board first, should fix the issue
I cleaned it but nothing happened
@narimand yes it is probably bad. If it had liquid on it, it is definitely going to be bad. This board is responsible for the audio so it is either this or the microphone itself, which is less likely.
댓글 달기
here are pictures from my macbook
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
All the connectors looks fine, so honestly I have no clue. Maybe @refectio could help?
I haven't opened one of these up yet so I can only speculate. The first picture definitely shows contact with water. The damage may be behind that board as I can't really notice any obvious damage from the picture.
댓글 달기
귀하의 답변을 추가하세요
Nariman 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 3,267
