주요 콘텐츠로 건너뛰기
Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
61 질문 전체 보기
Weird Issue on startup
Hi Guys.
OK i have to say i have never seen anything like this before at startup.
It was doing this when it came into me & i did DFU reset which seemed to resolve the issue but after a couple of days (when the client came to collect it typically) it started doing it again.
the first part of the vid is in real time then i used same clip but slowed it right down.
Anyone seen this before or have any idea?
Thank is advance
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I haven't seen this before...usually I see the Apple logo bootloop.
That said, it does appear as though the boot process is interrupted pretty early on. There may (and I say may) be a logic board issue that is causing this failure. What I find odd is that you say it worked well for a few days after a DFU.
Is it recognized by iTunes or is it completely shutting down?
If iTunes sees the iPad it may be a LCD/Backlight issue. If not, then it could be another subsection that is pulling things down. If you have access to schematics and a multimeter, I would probe some power rails and visually inspect the logic board.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Kenny Leonard 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 85
