How do I get rid of a virus?
i get pop ups and apps download on there own the phone does not hold charge it over heats and because of the pop up i can't operate it and it reboots on its own
좋은 질문 입니까?
좋은 질문 입니까?
Hi,
Because you cannot operate the phone successfully you may have to perform a hard reset to restore the phone to normal functioning.
Unfortunately doing this will erase all your downloaded apps and user data. It will restore the phone to its' factory default condition. It will be like when you first bought it.
First turn off the phone and remove any external SD Card (if installed), and then fully charge the battery.
Once the battery is charged, remove the charger and then commence the hard reset (also known as a factory restore).
Here is a link which shows how to perform the reset. Scroll down to the 2nd Method shown. This is the way for you to do it.
http://www.hardreset.info/devices/blu/bl...
Be patient, a hard reset takes a little while to perform.
해당 답변은 도움이 되었습니까?
@donelle, if you are successful in following jayeff's instructions, the next step would be to install an antivirus like lookout or AVG, and install an ad blocker software.
24 시간 전: 1
7일 전: 2
30일 전: 14
전체 시간: 349
