주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
Siri and Front camera video audio static noise
Hi, I have a iPhone 6 plus that has recently developed a issue where siri can't hear me and the front camera video audio is loud static, Also headphones with remotes and mic's built in sometime don't work unless shoved in the socket with a bit of force.
The housing is needing to be replaced and was thinking it could be the lightning and headphone flex cable could be the root cause of the issue.
Hope someone has solved this issue before
Thanks
Lloyd
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
There are 3 microphones in the iPhone.
The bottom microphone is for Voice Memo and phone calls. The other microphones serve as error cancellation
The (top) front microphone is used for FaceTime calls, Siri and selfie videos with the front camera (FCAM). The top back microphone serves as error cancellation
The (top) back microphone is used for videos with the rear camera (RCAM). The top front microphone serves as error cancellation.
You may have two separate problems here, related to the damaged housing.
Lightning Port
Front Microphone
Otherwise, there may be something wrong with the audio circuitry on the logic board.
iPhone 6 Plus Front Camera and Sensor Cable 이미지
상품
$9.99
iPhone 6 Plus Lightning Connector and Headphone Jack 이미지
상품
$29.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Lloyd 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 13,760
