주요 콘텐츠로 건너뛰기
Repair guides and support for the 5th generation Honda Accord coupe, sedan, and wagon.
87 질문 전체 보기
Engine bolt Tapping vs. Heli coil
Where the lower mounting bolt mounts my starter to engine has stripped threads. Some people say to drill it, tap it, and use a heli coil. I dont know why just tapping the hole and using a bit bigger bolt wouldn't be good enough. Would it be or not be good enough to mount the starter and why?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I assume that they don't suggest a bigger bolt because you might have to alter the starter housing itself, and drill a bigger hole in it to fit the bigger bolt. That could compromise the structural integrity of the starter mounting plate, and lead to it breaking. That is just an assumption though. Others may have a different opinion.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Good answer! Yes, thats the reason.
You don't want to use the wrong sized bolt as the clearance within the mount of the starter would need to be altered weakening the wall and its alignment.
댓글 달기
귀하의 답변을 추가하세요
Tricia 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 102
