주요 콘텐츠로 건너뛰기
2003년에 소개된 iMac G4 17" 1.25 GHz Model M9168LLA PowerMac 6,1 입니다.
21 질문 전체 보기
iMac G4 17" 1.25 GHz DEAD. Help me, please.
After some years, I decided to switch on my old and beautiful iMac G4 17" 1.25 GHz. No signs of life. I tried to disconnect all cables, hold power button for 10 seconds and replug the power cord. No sings of life. I tried to press ONCE the PMU button (close to ariport slot). No sings of life. I tried to replace the little battery inside (close to RAM slot). Still no sings of life... Any ideas?! Thank you so much!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
After removing user access plate, I don't have battery test points on my iMac 17" M9168LLA.
댓글 달기
답변 2개
선택된 답변
@tiobe start off with what Apple suggest for your model in the No Power state:
No Power
No fan, no hard drive noise, and the screen is black.
1. Verify the power outlet is good. Plug a different device into the socket to ensure there is power, or plug
computer into another outlet.
2. Check the power cord. Use a known good power cord.
3. Check connection of the power cord on both ends. Verify that the plug is securely plugged into both the
A/C outlet and back of the computer.
4. Remove keyboard, mouse, and other peripherals such as speakers.
5. Disconnect the power cord, place the computer in the service stand, and remove the user access plate.
6. Reset PMU. Refer to “Resetting the PMU on the Logic Board” mentioned earlier in this chapter.
7. Using a voltmeter, check the voltage on the battery test point (see graphic below). If the reading is over
3.5 volts, go to the next step. If the reading is under 3.5 volts, replace the battery and test again.
8. Plug the unit in, but do NOT press the power button. Using a voltmeter, check the voltage from the test
point marked “Main” (see graphic above). You should get a reading of approximately 12 volts. If the
reading is 12 volts, go to the next step. If you don’t get a 12 volt reading, verify that all the cables are
securely connected and test the unit again. Pay special attention to the video cable.
9. Press the power switch on the computer. Using a voltmeter, check the voltage on the test point marked
“12v” (see graphic above). You should get a reading of approximately 12 volts. If the reading is 12 volts,
go to the next step. If you do not get a 12 volt reading, replace the main logic board.
10. Using a voltmeter, check the voltage on the test point marked “5v” (see graphic above). You should get a
reading of approximately 5 volts. If the reading is 5 volts, go to the next step. If you do not get a 5 volt
11. Remove the bottom housing. Warning: Whenever the bottom housing is opened for service, you must
do two things:
• You must clean the original thermal film from the surfaces joining the thermal interface layer and
reapply thermal paste to the thermal pipe.
• The bottom housing has four torx screws that must be tightened to at least 17 in.-lbs. If you do not
have a torque driver, you will have to make sure these screws are tightened by hand FIRMLY, BUT
NOT FORCIBLY. Or, purchase the service tool (076-0899) in order to ensure the thermal pipe is
firmly mated with the top base. If the bottom housing is not securely attached to the base in this
fashion, the CPU may overheat and become damaged.
12. Check the AC line filter. To measure power at the AC line filter cable, disconnect the AC line filter cable
from the power supply cable. Switch your multimeter to read AC voltage. Touch the black probe to the
pin of the brown wire, and touch the red probe to the pin of the blue wire (see graphic below). Do you
measure 120v (line voltage)? If yes, reconnect the AC line filter and go on to the next step. If no,
replace the AC Line Filter.
13. Connect the diagnostic cables (part 076-0897) between the upper housing components and the logic
board. Refer to “Service Cables” mentioned earlier in this chapter.
14. Check the connection of the video cable on the LCD flat panel, and try to power on the unit again. If
you still have no power, go on to the next step.
15. Check power supply output. Disconnect the diagnostic power cable from the power supply connector,
and measure power at the power supply connector by touching the black probe to the ground pin, and
using the red probe to measure power at the pins indicated in the graphic below. Did you measure +12v
at each point? If yes, replace the logic board. If no, replace the power supply.
16. Replace the inverter board.
17. Replace the neck assembly.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I know this is an ancient thread, but just in case anybody is trying to resurrect their old flat panel G4, there’s another trick to try before you crack open the case: use a hairdryer to blow warm air into the fan opening at the top and the air ventilation around the bottom for a few minutes, then try powering it on again. I’ve used this trick to restart my own iMac when it showed no signs of life, and it has worked for me twice. 21 years old, and still runs!
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
@gregthomasmarks I like that idea:-) Do you know why it works? Have you investigated to figure out what happens when you do that?
I lack the technical expertise to investigate. It’s been used on PC motherboards that won’t boot for many years. The assumption is either the hot air dries out components impacted by humidity (ie moisture is causing a short circuit), or temperature impacts the conductivity/capacitance of old components. My iMac resides in a room with poor heating and high humidity, so either cold or moisture could be the problem. I suspect the latter.
Please note: be sure to blow out any dust BEFORE using high heat, to avoid risk of fire.
I like the hair dryer trick as an early step in trying to get an old beast to boot (especially for those of us without significant computer repair knowledge), if only because the chances of causing any significant damage are minimal, since it doesn’t involve opening the case and poking around the inner workings! If anybody knows why it works, or recognizes it as a symptom of a specific component failure, I’d welcome their insight.
댓글 달기
귀하의 답변을 추가하세요
tiobe 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 16
전체 시간: 1,083
