Will a 2012 logic board work into a 2011 model?
Hello, I have a MacBook Pro 2011 15'' i7 2.0ghz, 16GB (1600mhz) RAM, 1 HDD in caddy and 1 SSD.
The AMD GPU is broken, and I don't want to buy a new one of this model because, you know, AMD...
I was thinking if I buy this logic board: MacBook Pro 15" Unibody (Mid 2012) 2.3 GHz Logic Board
Will it fit into my Macbook? This way I get rid of the junk AMD GPU and get an upgrade of CPU, GPU and USB.
The two models looks to have the same size and ports, perhaps I only need to use another heat sink as the geForce can be a little different from the Radeon, but except for this the other things looks compatible.
Has someone already done this? Will it work? I don't want to expense $600 to discover xD.
좋은 질문 입니까?
댓글 2개
I'm quite convinced it would fit without a problem, but I wouldn't bet 600Us on that..having logicboards codes would help.
arbaman 의
The models of both are A1286. Someone knows How can I check If the LCD cable is compatible?
Vinícius Ortiz 의
