주요 콘텐츠로 건너뛰기
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
20 질문 전체 보기
What dose f:01 mean
when the washer start it stop and f:01 comes up
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개:
Any updates?
start as the machine starts counting down lid locks and f001 comes up
댓글 달기
답변 3개
It is an error code for a bad control board
Look at this link for tips to repair it: http://www.f1error.info/repair_whirlpool...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Posts on here refered me to an air hose near the control board. Check for it being crimped, you can blow through it and make sure you hear air coming into the drum. This can be your issue not your board, people have bought boards and still had this problem. So check the hose first. F1 is referring to pressure not being right on the water from air flowing against a sensor via this tube.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
As previously mentioned, F.01 can either be:
1) control board and/or
2) air tube that plugs into control board
You need to check the tube is clear, not kinked or if your control board works.
You should run the diagnostic on your make/model which will cycle through all the water intake steps C0 through C7 which will test the function of said tube as well.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
RoSkittles :o 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 13
전체 시간: 3,640
