What dose f:01 mean
when the washer start it stop and f:01 comes up
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
It is an error code for a bad control board
Look at this link for tips to repair it: http://www.f1error.info/repair_whirlpool...
이 답변이 도움이 되었나요?
Posts on here refered me to an air hose near the control board. Check for it being crimped, you can blow through it and make sure you hear air coming into the drum. This can be your issue not your board, people have bought boards and still had this problem. So check the hose first. F1 is referring to pressure not being right on the water from air flowing against a sensor via this tube.
이 답변이 도움이 되었나요?
As previously mentioned, F.01 can either be:
1) control board and/or
2) air tube that plugs into control board
You need to check the tube is clear, not kinked or if your control board works.
You should run the diagnostic on your make/model which will cycle through all the water intake steps C0 through C7 which will test the function of said tube as well.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 3
지난 30일: 14
전체 시간: 3,641
Any updates?
Tim D 의
start as the machine starts counting down lid locks and f001 comes up
jeffjefm 의
