주요 콘텐츠로 건너뛰기
The Dyson AM07 is a bladeless tower fan released in 2014. The AM07 uses "Air Multiplier" technology to create a smooth stream of air without using visible blades.
19 질문 전체 보기
Why is it not blowing cold air
My fan works but doesn't seem to be blowing out much cold air anymore
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 6개
I have the same problem. Paid £320 for the fan and it’s useless
Keep it clean and should be fine, they do require some maintenance if it is in a dusty and fluff environment, get a vacuum cleaner and suck all the dust of the air intake and motor and amp as much as possible or it's that bad use a compressor as suggested before
If these are used for heating and cooling, they get moist and the dust collected becomes wet and mud like and glues to the body closing all the vent holes. These can't be cleaned by a vacuum cleaner. It requires disassembling/opening the body of the air multiplier and if possible wash clean the intake holes.
Opening the body is not simple, several step needed and some technical know-how.
I just recently bought a Dyson cool fan but it’s not giving me cool air and there’s a smell when I turn it on
1 댓글 더보기
댓글 달기
답변 2개
선택된 답변
loopyshaz222 , Try and disassemble the fan as much as you can and use vacuum/compressed air to blow out all the dust/lint/etc. that may have accumulated from base vents/motor and the loop to help bring back it's efficiency. Links below may help. Good luck.
https://www.manualslib.com/manual/888752...
https://www.youtube.com/watch?v=Y7Z-Zn0r...
https://www.youtube.com/watch?v=5NAQv6RX...
해당 답변은 도움이 되었습니까?
점수 5
댓글 달기
All this I have done.
I vacuum every other day.
Fine dust has clung to the inside fan. Thus impeding air flow.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
loopyshaz222 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 6
7일 전: 72
30일 전: 464
전체 시간: 62,748
