Headlights blinking bright to dim
Headligets blinking bright to dim
좋은 질문 입니까?
christinezaf if the brightness of your headlights pulsates from bright to dim and back to bright have your alternator, battery and wiring checked. Sometimes bad brushes as well as corroded wiring can be the cause of that.
해당 답변은 도움이 되었습니까?
Going to try changing negative battery terminal connector it is corroded will let you know if that fixes headlight malfunction
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 61
