주요 콘텐츠로 건너뛰기
Repair and disassembly guides for Samsung printers.
101 질문 전체 보기
Samsung C1860 is tinting everything yellow.
I have had my Samsung C1860 MFC Printer for about a year now. Recently I have noticed degradation in print quality and of late everything I print is tinted yellow. So blues are green, reds are orange/red and black are... I am not sure what color you call that but it is not black. I printed a test page from Windows 10 to make sure it wasn't the program I was using to print and it isn't its the printer.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 5개
When was the last time you replaced the toner?
I just replaced the toner because of this issue.
How would you fix it if you knew how to?
two months before and now every paper printing coming yellow shed
print every paper yellowish I do not know why
댓글 달기
답변 2개
가장 유용한 답변
Barry Hoven , Uninstall your printers driver and reinstall, in case it had been corrupted. You could also try resetting the printer, instructions link below, to see if that corrects the issue. Good luck.
http://support-us.samsung.com/cyber/popu...
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
That is a really smart idea. I will try that!
댓글 달기
I had this problem too, with my Canon printer. You could check your ink cartridges and look for yellow in blue, etc. If you have a refillable tank, refill it with the color that is the color of the cartridge. If a non- refillable tank, replace it with the same color of the cartridge.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Barry Hoven 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 2,274
