LCD screen: iMac 20" 20 and Isight
Did a research on google and cannot find an answer.
Is it possible to put an apple Imac screen from an Imac G5 20" into an G5 20"Isight version?
좋은 질문 입니까?
좋은 질문 입니까?
The numbers in parenthesis that follow the model number must match exactly. If you need LM201W01(ST)(B2), you must replace it with LM201W01(ST)(B2).
해당 답변은 도움이 되었습니까?
+ Agreed - It's the revision numbers ((A1), (B1)) that matters. Sometimes with the wrong revision screen those iMacs won't even boot up.
"NO that's not an exact match. I don't think you're ready for DIY repairs."
Actually it was a question for Imac LCD...Someone has already done it but its in french.
Thanks for your input
??? Imac LCD...Someone has already done it but its in french. ???
numbers on the back of the display are the same yes, if not no.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
해당 답변은 도움이 되었습니까?
So it the Isight is LM201W01(ST)(B2)and the imac g5 is LM201W0(SL)(A3), would it fit?
thanks
It does not always have to be an exact match. For example, I have replaced a (SL)(A1) with both a (SL)(A2) and (B5). Both worked. Some other suffixes will not work though. You have to check the data sheets to see what the voltage level is and what type of video signal is sent from the video card to the LCD are.
해당 답변은 도움이 되었습니까?
not a bad answer to a very old question ;-)
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,436
댓글 1개
why don't you try to ask any it support team? They are the expert in any it support related queries.
meaganshoults12 의
