주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon의 DSLR D3100은 2010년 8월 19일에 출시되었습니다. 14.2 MP 카메라, Full 1080p HD 동영상 촬영 기능, 3인치 LCD 화면을 탑재하고 있습니다.
SD card won't engage
The SD card won't snap into place thus giving me a message that it is missing.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Are you sure your putting it in rite side up?
댓글 달기
답변 1개
가장 유용한 답변
@fwiwjeannie , Jeannie, First try another card in case that card has a damaged edge. If different card not locking, look in the SD slot/port to see if there is and debri keeping the card from looking in place and if you see some very carefully pick it out with perhaps a tooth pick. If no debri found the slot lock pin/spring may be damaged and may need replaced or repaired. The link below shows how to disassemble the camera to access the SD card slot to have a closer look if need be. If not wanting to attempt the repair your self perhaps have a good local camera shop have a look/estimate repair as they may be familiar with this issue and have quick fix/parts. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Nikon D3100 마더보드 교체
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
This set of instructions is to replace a mother board. I see no mention in them about fixing the SD card slot. I tried a new card, no luck. I don't see any debree in the slot.
Jeannie, the memory card holder is attached to the mother board and if defective/damage would have to be unsoldered from the mother board and replaced, this is not a job for the beginner, the disassembly link was if you wanted to look at the SD card holder to see if there was any debri or something out of place(spring/catch,etc.) that you could correct your self, step 7 the card readerI believe is under the thumb in picture and then step 8 clearly on the end of mother board. Below I attached a link so you can see what the SD card holder looks like. Hope it helps.
http://www.ebay.com/itm/SD-Memory-Card-S...
댓글 달기
답변을 추가하세요
Jeannie 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 3,122
