주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Camera won't work please help
Vikng tablet camera won't work. Suggests locate app that uses same.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
You may have another app using it that's running in the background? Tell me what steps you've already tried to troubleshoot it. (I.E. Rebooting the device)
의 공유
I don't know what to be look ing for as the tablet does't appear to have a camera working anywhere. I've rebooted several times. I've done a complete restart multiple times. And, nothing changed except it now takes nearly 15 minutes once the tablet is turned on before it gets to the start page. :( I appreciate all your support and ideas! S~
의 공유
댓글 달기
답변 1개
선택된 해법
@suzzetteg, Suzzette, A lot of forums recommend a factory reset when you run into issues as you are having, sometimes software, Apps, etc. can become corrupt and cause problems with devices. The link below will give instructions on how to perform hard/factory reset. Doing this will delete all existing data, so you will want to save import info o another device, SD card, etc.. If reset is not working,and under a week old, return the device as defective or exchange/refund, before your time runs out to do it over the counter.Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://unlockandreset.com/rca-tablets-al...
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
I appreciate your input. Unforttunately, I've already done that a few times. There was no change in the camera, although now the tablet takes 13-15 minutes to load. :( This is brand new, less than 4 days owned since delivered. Disappointed and stymied. Again, thanks.
의 공유
@suzzetteg,Suzzette, If reset is not working, return the device as defective for exchange/refund as camera may bedefective, before your time runs out.
의 공유
I bought two rca phones and two rca tablets, and camera not working on the phone, I bought them at Canadian Tires ,last year August, but am
in st.Lucia ,what can I do with it
의 공유
댓글 달기
답변을 추가하세요
Suzzette C Greany 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 29
전체 시간: 1,092
