주요 콘텐츠로 건너뛰기
2012년부터 계속되는 MacBook Pro 15" 레티나 디스플레이 노트북에 대한 수리 정보 및 안내서.
3614 질문 전체 보기
Water damage to keyboard
Spilled clear water on macbook pro keyboard and dried it out over three days. Unhooked the battery as it was trying to cycle on and off everytime i opened the lid. So i have battery unhooked and back open and drying upside down for three days. Is it safe to leave the battery unhooked an plug into wall to test? Or should I plug the battery cable back in to test?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Are you sure that none of the water reached your logic board?
Did you checked if there is any corrosion on the logic board?
댓글 달기
답변 1개
가장 유용한 답변
beckyhouser1 , Stop charging or powering up your device until the liquid damage is addressed correctly, as you could be shorting out components inside the Mac. You really should take care of the corrosion that is happening inside the computer from the water damage as that could be a big problem. Pick your device Link #1, choose your model for disassembly guide, it will enable you to get inside the computer to remove the damage/corrosion caused by the liquid. Use the 2nd link as a guide/instruction on how to clean/repair the device from liquid damage. After this you will be able to power on the Mac and see if further damage has to be addressed. Good luck.
MacBook Pro 15" Retina Display
Electronics Water Damage
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
beckyhouser1 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 137
