주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
Battery Dies Very quickly
I have iPhone 6s but stop low power mode my battery drops very quickly about wondering if you battery iPhone7 to put on iPhone 6s
3min in Snapchat-9%
This is not normal
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
Nasko Stoychev , The battery for iPhone 6S and 7 are not compatible, different connectors, etc.. Below are links to a guide showing how to replace the battery and a link to a battery that comes with tool kit to make disassembly easier, you can also search for a battery for better pricing. You may also want to try a different charger/cable and check for dust/lint in your charge port and pick/blow it out carefully and check for any damaged pins in port or whether i is loose. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
iPhone 6s 배터리 교체
iPhone 6s Battery
Replace a 1715 mAh battery compatible with an iPhone 6s. This replacement does not require soldering and is compatible with iPhone 6s models (not iPhone 6, 6 Plus, or 6s Plus). 이미지
제품
iPhone 6s Battery
$29.99
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Yes. These iPhones have problems with the battery and you need to replace it or get it replaced. As for the 7bat in a 6 its not possible as they are different. So you need to replace the battery or get it replaced. No other way sorry, unless you just want to either get a new phone or deal with it. (I suggest getting a samsung as they are amazing and reliable phones)
이 답변이 도움이 되었나요?
점수 2
댓글 달기
For this model I wouldn't waste time replacing the battery yourself. Plug your serial number in to the link on the apple site and see if your 6s qualifies for free replacement. That way you can walk into a local apple store (or ship if there's not one nearby) and they'll give you a brand new phone.
https://www.apple.com/support/iphone6s-u...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Nasko Stoychev 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 230
