older screen on a newer body (inverter to logic board cable help)
Hello.
I was recently given a MacBook Pro 15" Core 2 Duo Model: A1260 with a broken screen.
I already have a Macbook Pro 15" Core Duo Model: A1150
I decided to see if i could put the A1150 screen on the A1260.
The result is that everything fits except the inverter to logic board cable has a different wire configuration and logic board connector. The inverter side appears to be the same (aside from the different wire configuration).
Can i use the A1260's inverter cable with the A1150's inverter? I believe it will fit but the wires will be in a different orientation. Does this matter?
I'm hoping i used all the right terminology.
Thank you very much for any advice.
좋은 질문 입니까?
댓글 1개
Could someone be so kind as to tell me the output volts of each pin from the Logic Board of a A1150 and a A1260. if they are the same i can fashion a cable.
Thank you
Ben 의
