주요 콘텐츠로 건너뛰기
모델 A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, 또는 2.4 GHz Core 2 Duo 프로세서
1203 질문 전체 보기
MacBook will not boot but will charge
I few days ago my macbook stopped turning on. When I hit the power button I get absolutely no response. Nothing from the LEDs, no fans, the harddrive does nothing in short the thing is completely unresponsive. The odd thing about this is that the battery is fine and the charger light comes on. I'm hoping it's just the power button, in which case I could just replace the upper case. Is there a way to test this? Could I remove the upper case and short the thing on? Or does this sound like a logic board issue? Thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
I found this pic for you, hope it helps:
Won't power on even after replacing logic board.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thank you! It took my a while to get a #000 Philips but that was exactly what I was looking for.
댓글 달기
귀하의 답변을 추가하세요
Areaman 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 1,475
