RAM upgrade from current (2) 4 GB each
I have 2 memory slots each with a 4 GB module. Can I upgrade?
좋은 질문 입니까?
좋은 질문 입니까?
The non-retina models can be upgraded up to 16 GB!
You can replace one module or both as an example replacing one you could get to 12 GB (one 4 GB & one 8GB module) or swap out both to get to 16 GB. But before you make this jump make sure its going to improve performance. Often upgrading the HD to a SSHD or SSD will get you more performance bang for most.
Here's the Apple T/N which goes over the details: MacBook Pro: How to remove or install memory
해당 답변은 도움이 되었습니까?
Dan, why is there no "accept as answer" button anymore? Every time I try to do it the option isn't there.
@pccheese It's there for the moderators. But you should still be able to vote.
That's what I mean, I previously had the option to vote. Now when I go to moderate the option isn't there.
Very helpful - thanks
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 72
댓글 1개
Heres your systems specs: MacBook Pro 15" 2.7 GHz i7 (Mid-2012)
Dan 의
