주요 콘텐츠로 건너뛰기
No sound coming out from the AV receiver
No sound coming out from the receiver. I saw a solution on youtube which suggested that if you heat a particular chip for few minutes, it starts working. I used hair dryer to do that. It worked for me for few minutes but the again no sound.
Added a picture
Please advice
Update (04/02/2017)
Here are the steps that I tried recently
1) Heated the chip with hair dryer for few minutes
2) Let it cool down
3) Pasted heat sink over the chip
4) Started the receiver
5) Sound started coming for few minutes then no sound again
Please advice
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 4개
I would like to try the option to heat it and then add a heat sink to see if it fix the problem. But that would be my last resort
@vkumar you need to help us helping you. We still need to see where this "chip" is and the function thereof. Post some images as described in my answer.
@vkuma so that is you HDMI board Bchdm-0678 Let's see if we can find any schematic on that.
add a small heating element over the analog devices chip in hdmi board..may be 12v 10watt heating element...this heat maintains the poor soldering problem...and the receiver works fine...do not place heatsink this cools the chip and no contact...
댓글 달기
답변 5개
선택된 답변
@vkumar post some images of the chip that you heated up and where it is located on the board. Since it works after you heat it up it is possible that you have cold solder joints or the chip is a flip chip design which has trouble with the solder bumbs (long story ;-). Most of those will have to be replaced to be permanently repaired. Every now and then the addition of a heatsink may resolve it. All this will depend on where and what this IC is. Use this guide to post images so we can see what you see. On select models Onkyo had issue with some transistors overheating and causing the amp to suddenly shut down and/or static noise from speakers. Again, we'll need clarification from you to figure this out.
Update (04/11/2017)
@vkumar you need to make the component on the image so we can see where you installed the heatsink etc. Check the area outlined by a blue circle in the image. It appears to have some heat issue. Check those components and let us know what you find.
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
I attached a picture to the original post. Hope that helps. I pasted a heat sink over the chip after heating the chip for few minutes with hair blower. It worked for a minute and then stopped working. No sound again
@vkumar mark the component on the image so we can see where you attached the heatsink etc. Right now all I can immediately identify is an area of what seems to be high heat.
I had the same problem, my ONKYO TX NR515 stop sounds suddenly, I tried to heating DTS chip but no progress.
I want to buy another board, but I don’t know were. Could someone indicate a seller?
댓글 달기
Sounds like that chip is bad. Contact onkyo http://www.onkyousa.com/Support/ and they should help you by fixing the broken part. Normally if its a onboard chip as i'm assuming it is, they are almost impossible to fix without expensive tools. Contact them and see what they can do, if they cant do anything, let me know and ill give you another option.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
I tried that and Onkyo support told me that this model does not qualify for fix by Onkyo. Please suggest other option
Temporarily Repair a Lost Cause Graphics Card by Heating it up in an oven That should help, thats the other option, its a basic guide on how to do it
댓글 달기
not coming sound what happand
Update (10/23/2017)
hello saaar pleeas ditaile talme saaar
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
sound no working what happend
pleaz resalt
modal 340 onkyo
댓글 달기
Hi. I m from Chennai. I have Onkyo HTR 670 av Receiver. I did not use it for about 5 years n was packed n kept inside a box. I removed n connected n there was no sound coming but videobis ok. I checked locally n the guy said that the HDMI board is gone. Can somebody suggest where I can get this HDMI board for the Onkyo AV receiver HTR 670 please?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Kalyan - You can try with Onkyo India service center
댓글 달기
Brand new, no sound, this is ridiculous, taking this POS back!!!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi im roy from malaysia
My onkyo st dr 608 no sound out..
댓글 달기
귀하의 답변을 추가하세요
RVK 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 19
30일 전: 79
전체 시간: 60,561
